sky locking up problem
Discussion in 'Sky Digital TV Forum' started by markbigears, Feb 9, 2005.
  1. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    About once a week my unit either freezes or channels drop off the EPG. All I do is turn the unit off for a minute and its ok. Is this normal or is the sky system usually fault free?
  2. Bluevanman
    Bluevanman
    Sounds as if you may have a dish/lnb problem. If you are still within warrenty give Sky a call and book a service call. If you are out of warrenty and do not have any form of service cover the call out will cost you £65.00, but this will include all work that needs doing.
  3. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    many thanks, thanks for the advice, i didn't think of that. The dish and lnb are only a few months old too. I havent got a contract with sky, just got the free to air/view card. Quality and strength are both over 80% as well?
  4. JET
    JET
    Nov 19, 2000
    43
    11
    Andover,Hampshire, UK
    We had the same problem as you have with the Sony box freezing. It used to do it regularly if you surfed through the channels. A lot of engineers I spoke to seemed to think it was a common problem with the Sony. In the end I got rid of it and now have Sky+, which has been problem free.
    John
