Sky + Lnb
Discussion in 'Sky Digital TV Forum' started by John_sg0107, Oct 18, 2003.
  1. John_sg0107
    John_sg0107
    Aug 13, 2003
    33
    Newcastle
    I have just ordered my 2nd Sky + box from Sky and it's due to be installed on the 27th.
    My plan is to move my original Sky + box to the living room and have the new one installed in my room. I was advised by the Sky operator that the price includes a quad LNB. I told the advisor that I already have a quad LNB which came when my 1st Sky + box was installed but I did say that since a new LNB is included in the price then the engineer may as well install the new LNB.
    The Sky advisor asked me what is wrong with the LNB that I have at the moment and I said there is nothing wrong with it but if a new one is included in the price why not have it installed ?. Anyone else agree ?.;)
  2. p.booth
    p.booth
    Oct 8, 2002
    4,048
    mbro
    +151
    Sure if it doesn`t cost any more ,have the new one.Go for it..
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    If the current one is working then why fix something that isn't broke:)
    Then again if you have the new one installed it will be fully covered by the warranty and that would prevent any "misunderstanding" in the future if warranty work is required.
  4. John_sg0107
    John_sg0107
    Aug 13, 2003
    33
    Newcastle
    Thanks for the reply's !. Just have to see what the engineer has to say when I tell him that I would like the LNB replaced. I can't see there being a problem especially when it's included in the price.
  5. Fernsehman
    Fernsehman
    Well, the problem is the usual one. It's common for the Sky guy to screw up the dish alignment.
    Just get him to leave the new one. If the system works OK, sell it on Ebay.
  6. John_sg0107
    John_sg0107
    Aug 13, 2003
    33
    Newcastle
    Yeah I might just leave well alone. Don't want to create any problems for myself
  7. manc
    manc
    Apr 3, 2003
    151
    19
    I just paid £27 + carges on ebay for one of these, but there was others prices at £35.
    Hope that helps :)
  8. davej
    davej
    Jul 31, 2003
    85
    Sunderland
    The installation contract for going from sky to sky+ says something about their re-using existing equipment if its available, I expect you'll be a victim of that clause.
