Sky LNB Cabling Issue - extension help
scottbufc
Hi guys, I am needing to make a small DIY repair to my cabling and I would like soe help as how to do this.
When my cabling to the box was done by Sky it was not long enough so they extended this for me. I now have an issue with one of the extensions. The joint on the end of the cable coming from the dish is no longer working so I am only receiving one signal feed from the dish at the moment. I know that it is the long cable from the dish rather than the shorter extension as I have swapped the cables around and now know that this is the faulty one. Can anyone recommend where I can buy the connection from and stick a new one on the cable which I would be happy to fit myself or any other ideas of how I can repair this?
Sorry that my description is poor but I dont know the technical names for the cables, hopefully I explained it well enough though!
Thanks guys.
Delh68
Assuming they have used f connectors to make the join, you'll need a f coupler ~ they are selling them on 'that famous auction site' for £1.99 for 5, so you may be able to get them cheaper ~ do you have a local hardware store like Wilkinson close by, as i know they sell them (but probably a £1 each)?
Should get some amalgamating tape to waterproof it to stop any water ingress as well.
Delh68
Delh68
Re-reading the thread it may be just an f connector (2 types 'screw on' & 'chrimped on') you need, if it is just the end of the cable you are attaching to the lnb on the dish ~ again the auction site is your friend, or local hardware shop
Delh68
scottbufc
Thanks for your reply, with regards to the water issue, this wont be an issue as the extension joint is inside my living room. If possible could I email you a pic of the connection so you can advise me?
Thanks.
Delh68
Thanks.
No problem
Delh68
SamRadford
You need two 'F' plugs to fit the cable and a threaded coupler.
