Sky+ lip synch problems
Discussion in 'Sky Digital TV Forum' started by HMHB, Oct 19, 2005.
  1. HMHB
    HMHB
    Nov 11, 2001
    27,586
    Nottinghamshire
    +6,526
    I recorded Supernova on BBC2 on Tuesday night and the lip-synch was well out. I get this problem intermittently on various programs and find it very annoying, does anyone else suffer from this ? If not, is there anything I can do to my box to try and cure it ? It happens live as well as on recorded stuff and I've tried it with the sound going through the digital cable and the scart cable (into my Panasonic CRT) and the result is just the same. I never get this problem on terrestrial TV only on Sky.
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,130
    Galactica C.I.C.
    +356
    Sky does suffer from this to varing degrees on various channels. I have had this on more than a couple of occasions , although not when recording stuff.
    I find that by changing the channel and then back again, it sorts it self out. I am not sure how easy it is to fix the problem though, you may need a new box if it becomes to much of a problem :)
    Dave.
  3. johndon
    johndon
    Feb 3, 2002
    1,996
    63
    +128
    If the problem persists, you'll need an audio delay box like you can get from these guys: http://www.felston.com/
    HTH
    John
  4. samjet
    samjet
    Jan 1, 2005
    1,419
    38
    notts
    +5
    i might be suggesting the obvious but many av amps already have a lip synch adjustment feature built into them
  5. HMHB
    HMHB
    Nov 11, 2001
    27,586
    Nottinghamshire
    +6,526
    This isn't going via an AV Amp it's straight into the telly, which suggests it's a problem with Sky. I also get tiny little dropouts of sound a lot on mainly the UK range of channels that I don't get on my secondary ordinary Panasonic box. The signal strength on the Panny is at full, but both signals on my Sky+ box are at 2 thirds for strength and 2 thirds to a half for quality.
  6. fortean
    fortean
    Nov 28, 2004
    825
    Chorley
    +71
    I watched some of it, not recorded, and noticed the synch problem so at least you know on this occassion it was nothing to do with the recording.
  7. HMHB
    HMHB
    Nov 11, 2001
    27,586
    Nottinghamshire
    +6,526
    Thanks for that mate, it makes me feel a little less worried about my setup :)
