Sky + & Lip-Sync Problems
Discussion in 'Sky Digital TV Forum' started by Shagga, Jan 8, 2004.
  1. Shagga
    Shagga
    Jan 6, 2004
    265
    Middlesex
    Hi All,
    Any of you come across a problem on Sky live broadcasts ie: Sky News, Sky Sports News etc. where the sound is heard a second or two before the persons lips move...? If so have you corrected it and how..?
    Really annoying..!
  2. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,611
    48
    Lancashire
    +51
    It's not only live broadcasts, & theres plenty of complaints in the forums, the larger the Tv the more obvious it is. I don't believe much can be done. Fixes are possible but sound very expensive (electronic 'delay type boxes'!), complex & not ideal. Try complaining to Sky. When I suffer I turn it over for a while, then back this seems to sort it. (dont know why) & isn't a solution as you have to turn off what your watching. I just cant watch when it gets too bad. So maybe it improves on its own before I turn back?
  3. Shagga
    Shagga
    Jan 6, 2004
    265
    Middlesex
    Cheers STOWITBELOW,
    It's happened on DVD's and also things I've recorded that were ok when I recorded them. It does my head in somtimes..! So you would say it's down to Sky + and not the plasma..?
    Thanks again
  4. bobbles
    bobbles
    yes i get this from time to time
    if i turn off the amp and listen via the tv speakers it is far less noticeable
