Sky+ lip sync on PWD7
Discussion in 'Plasma TVs Forum' started by Cardiff Irons, Feb 17, 2005.
  1. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    246
    19
    Auckland
    Good news is that I don't seem to suffer any lip sync. I have Sky+ connected via scart to a Panasonic E65 DVD and the E65 connects to Denon 2105 amp with component and a separate digital audio lead.
    However, the guy who installed it suggested I run a separate digital audio lead from Sky+ box to the amp. This provoked a couple of questions:
    1. Has anyone experienced lip sync problems when they run Sky+ audio directly to amp, but Sky+ video via DVD to amp?
    2. With my current set up, is the quality of sound compromised? Presumably the scart carries sound to the DVD and then the DVD send it via the digital lead - I just wondered whether a direct connection of audio from Sky+ to amp would improve things?
    Thanks in advance for any thoughts / suggestions.
  2. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    I found going that route via e55 that dobly digital output from sky+ was lost (i assume because the scart can't acrry the dd signal) so now go direct from sky+ to the yammy amp with digital optical....I had minor, occasional issues with lip sync at first but set the delay to 60ms on the yammy and left it there and haven't noticed any probs since
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    yes for 5.1 from sky movies you need direct optical from Sky+ to AMP..... So hows it looking Irons?
  4. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    246
    19
    Auckland
    Looking really good mate, but so stacked with work I'm struggling to find time for a really good play with it all. Still, ahem, negotiating with Tenspot regarding the speakers, so will be a couple of weeks I suspect before it's all in place. Then I'll be getting my plasma out for the lads. :smashin:
    This potential lip sync thing. Nigel did originally plug the red and white audio leads from Sky+ into the amp, but this caused massive lip sync problems. I'm assuming that it didn't like it because sound was coming into the amp via the scart/audio lead. I'm assuming that if I put a digital audio connection between Sky+ and the amp it will create similar issues.
    Any suggestions? (other than getting a JS converter and connecting Sky+ independently to the amp)? :confused:
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    felstron box......will do audio delay to correct it at £100+ tho... give it a try and hear/see it how bad it is........if you dont have sky movies ofr watch often not a biggy.........
  6. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    246
    19
    Auckland
    Cheers HD. Where do you get these boxes from - did a search and it came up with nothing!
    For starters, I might have a go at taking the audio lead out of the E65 and plug it into the Sky+ to see what happens. 99% of my viewing is Sky, so quite an important one.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    give it whirl I'll dig a link out for the box for you:
    CRumbs price has gone UP!! http://www.felston.com/ £164.......
  8. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    246
    19
    Auckland
    Thanks HD. Wow that is dear! Might just have to live without the full-on 5.1 experience from Sky (although will still get it on DVD). I'm beginning to wish I'd gone for the 2805 as that has audi delay options IIRC.
  9. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    246
    19
    Auckland
    Hey, 30 posts, I'm now a fully fledged member :clap: :clap: :clap:
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    YUP and congrats mate..........
  11. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    246
    19
    Auckland
    OK, quick update. I've decided to separate out the Sky+ video to the amp with a JS converter and run component into the amp. This means Sky+ audio and video will go straight to amp rather than the video going via E65, which can apparently slow things down a bit.
    The added benefit is that I can do simple amp switching between DVD and Sky.
    Hmm, seems like I've caught the upgrade bug already. :eek:
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    LOL it bites hard mate a scaler will be on the cards in a month........
  13. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    246
    19
    Auckland
    Two responses to that:
    1. I agree.
    2. What does a scaler do? :D
  14. nokianut
    nokianut
    Feb 11, 2005
    11
    London
    why is it that lipsync problems are not on all channels, only some
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    thats a broadcast issue and the fact that they get it wrong at their end, nothing you can do......
    Irons, a Scaler well it does lots and lots of things but improve PQ is the main one by using better quality video processing to feed the plasma
