SKY LINK
Discussion in 'Sky Digital TV Forum' started by gbmitie, Sep 20, 2001.
  1. gbmitie
    gbmitie
    Apr 25, 2001
    1,168
    49
    republic of ireland now
    +70
    I am getting old. I have sky piped round to every room in the house, uisng a distribution amp in the loft, but now I would like to be able to chnage channels on the sky box from another room. Do I need to run another cable or can I just use existing set up?
    SANAP
  2. derekrcross
    derekrcross
    Feb 20, 2001
    442
    19
    you will need a dist amp with infa red bypass<br />the handy link comes in 4 & 8 ways the 8 being<br />about £100 hope this helps
  3. sjr1
    sjr1
    I am not 100% sure...... I think you'll have to put a dedicated feed as theirs 9 volts running down my link cable this allows the mouse on top of second tv to transmit the data..I ve tried it in my video and didnt work its the same for my Sky+
  4. Jon Baker
    Jon Baker
    Jul 22, 2001
    48
    Cumbria
    As Derek says you can but not with any old distribution amp.<br />Any advertiser in What Satellite selling TV link will know about this and will sell you a suitable amp.
  5. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Have a look here m8 - <a href="http://www.tvlink.co.uk/24way.html" target="_blank">www.tvlink.co.uk/24way.html</a>
    I have the two way one and it works a treat. 2 bedrooms with full sky digital remote operation. Isn't life wonderful.
