deefadog
Established Member
We have 2 SLX link magic eye things, one in the bedroom, one in the kitchen, they both come from an SLX boaster in the attic which is feed via the RF2 out put on my SKY box, all been working fone for over 2 years, until now!
First of all about a week ago, what ever you pressed on the remote (when using the eye links, somehting else would happen, like press 3 and the guide would appear, or it would switch off, then i kept getting the replace batteries in the remote - Batteries are fine and it works no problems on the actuall sky box!
I check the service menu, power was off to RF2, so i turned it back on, and it does now not work at all! there is a red light on the eye links - so power is there, it just will not work!
I have run out of ideas, as it should work!
Any help guyz?
Any help guyz?
