Sky+ Key Magic setup - is it possible?
Discussion in 'Sky Digital TV Forum' started by IanThornton, Oct 1, 2004.
  1. IanThornton
    IanThornton
    Hi all,
    This was posted a loong loong time ago but no answers to the thread ...
    I've just had Sky+ installed (goes without saying, it's excellent) but it seems that the method of entering Key Magic codes into the remote is no longer possible with the new Sky+ remote.
    (i.e. TV -> Select/Red -> 994 no longer has any effect)
    Is it now impossible to enter Key Magic codes with the Sky+ remote or is there a different method?
    Thanks in advance,
    Ian.
  2. D J Fryer
    D J Fryer
    Jul 14, 2000
    746
    High Wycombe, Bucks
    +15
    Try TV -> Select/Red -> 994 -> Select - LED should flash twice if it is a valid code. Your lucky you know the code that works - I spent hours the other night trying to find a Panasonic code to work a small LCD TV we have got in the kitchen - couldn't fine a single one that worked :(
