Sky+ - Its' all gone
Discussion in 'Sky Digital TV Forum' started by uk_jih, May 19, 2004.
  1. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    I had a power cut last night and when the Sky+ box came back on it had lost all of my recordings. It was not recording at the time, liverewind is switched off but still the hard disk was knackered (120GB).
    When I pressed record, it said that recording was not available so I did the housekeeping thing, still no recording, so I did it once more for luck and boy was I lucky, it's all gone but at least recording is working again.
    My question is, is there a way to switch off (shutdown) a Sky+ box safely?
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    mine has had a load of accidental power losses as someone yanks a power lead out..... never a problem like this....
    ad
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Never had any problems with a power cut or switching the box off at the mains. However whne the power is cut while a HD is spinning and/or the heads are moving there is always the possibility of the data being corrupted especially as the SKY+ has that extra layer for organising data which a normal FAT32 HD would not have.
  4. MSEHOME
    MSEHOME
    If your sky plus box has a short power cut it is possible that when you try to access you recordings they appear not to be their. This appears to be because box software has become corrupted. To get recordings back un plug box for at least 2 ½ Minutes then switch power back on and hey presto recordings should be back :thumbsup:
  5. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,614
    48
    Lancashire
    +55
    Nice tip if it recovers 'missing' recordings. I will just add my sensitive circuit breakers often trip with the washer on spin! Touch wood I've never lost recordings, despite many 'power cuts.'
