Sky+ into the bedroom
Discussion in 'Sky Digital TV Forum' started by SteveRSF, Aug 8, 2004.
  1. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    Whats the best way...........video sender? can i have more than one tv picking up the signal
    Don't really want to pay for another box and subscription
    Help please :smashin:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    You need to decide if you want to watch the same channel in the main room as the bedroom either live or a recording or be able to watch two channels at the same time.
    If you are satisfied with the same channel/program then a simple TVLink device connected to RF2 will be ideal, mono only sound but full access to the SKY+ when using a SKY+ remote. A video sender will also work just fine if you don't fancy having a fixed cable between the two rooms.
  3. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    Thanks starburst...........tv link were can i get one from m8?
  4. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    From SKY (could be expensive), from any online sat dealer such as Satcure or Brymar and I think Argos sell them.
    There are many models, they all do the same thing but prices do vary and don't forget the coax/sat cable required to connect the device from the bedroom to the SKY+.
