Sky into Panny ES10 - rgb scart in, can i prog scan component out?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Lighty, Jun 19, 2005.
  1. Lighty
    Lighty
    Mar 7, 2002
    2,795
    East Yorks
    +134
    pretty much as the title really............
    i'm just about to get sky and wondered if i take rgb scart out of sky and into the es10, can i then prog scan component out?
    my es10 is happilty ps component at the mo with terrestrial tv but just checking it'll be ok with scart in......... :rolleyes:
    thanks for any help :smashin:
    sean
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    yes you can, what is the ES10 connected to?
  3. Lighty
    Lighty
    Mar 7, 2002
    2,795
    East Yorks
    +134
    a jvc lcd - looks good on terrestrial so i'm hoping digital is even better!!
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    yeah should be fine if you are using a seperate sound system you may need to sort out a delay that ES-10 can introduce but if you take sound out of ES-10 to TV not direct from Sky box it should be fine
