Sky installer set up
Discussion in 'Sky Digital TV Forum' started by Jonah, Jul 7, 2002.
  1. Jonah
    Jonah
    Don't know if anybody else knows about the Sky installer set up menu.
    Never seen any threads on the forum. If anyone needs to access the Sky installer set up menu to make any changes here's what you need to do ;
    Press services button
    Press 4 (system set up)
    Press 0 then 1 then select and there it is.
    Hope this is of help to someone
    Jonah.
  2. Paul D
    Paul D
    Dec 27, 2000
    2,781
    Manchester
    +550
    Yes!
    This would be of some use to me:D
    Thank you!!!
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    What does the menu allow you to do?
  4. Paul D
    Paul D
    Dec 27, 2000
    2,781
    Manchester
    +550
    It allowed me to turn on the RF2 output for my "magic eye" TV Link.
    The RF2 voltage needs to be turned on in this menu.
    I also changed the RF output to channel 40 to avoid clashing with my videos channel 36 output etc.
    The above tip came just at the right time!;)
  5. Jonah
    Jonah
    Hi Fulabeer
    Glad this post was of some use.
    I knew it had something to do with the RF settings.
    I had a similar problem where Sky and video channel were too close together and caused interference. It can also happen if the RF channel is too close to an ordinary TV channel.
    This may be the cause why so many people on this forum are getting so much interference.
    Maybe more people need to read this thread!!!!
    Jonah.
