Sky+ installed, now RF2 won't work
Discussion in 'Sky Digital TV Forum' started by theoldbill, Aug 31, 2005.
  1. theoldbill
    theoldbill
    Dec 27, 2003
    40
    Manchester
    +6
    As above really, I had normal Sky working fine with RF2 going thru a splitter to kitchen and upstairs bedroom.
    I had Sky+ installed last week, and now I can get terrestrial TV on both secondary TV's but no Sky signal.
    I have searched the forums and I think I need to enter the Engineers Menu on the Sky+ box but can't seem to find out how to do it, in order to turn the RF2 signal on.
    Tried Sam Radfords site but that just caters for normal Sky, not Sky+.
    Anyone have any idea as to the Engineers Code?
  2. theoldbill
    theoldbill
    Dec 27, 2003
    40
    Manchester
    +6
    Cancel that!
    Just realised that you have to press "Select" after services, 4, 0, 1.
  3. theoldbill
    theoldbill
    Dec 27, 2003
    40
    Manchester
    +6
    And further to that, if it helps anyone else, you have to re-tune the TV's connected to RF2. Problem now is that the picture on the secondary TV's is fine for terrestrial channels but appalling for Sky, very snowy. Maybe one of the connectors got knocked during Sky+ install, will have to check.
  4. JayCee
    JayCee
    Jan 20, 2004
    20,229
    Lanarkshire
    +1,937
    That's probably because the rf channel the modulator is set at is sitting on top of/or very near a terrestrial channel..........the default is chan 68 so set it to that and retune the TV's and if still a poor pic try ch21.
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Channel 68 is not the best channel in all areas. There is a mathmatical way of selecting the channel, but you have to know the channel numbers of all the analogue and digital channels in your area, so it's probably just as easy to do a little trial and error.
  6. theoldbill
    theoldbill
    Dec 27, 2003
    40
    Manchester
    +6
    Cheers guys,
    I tried ALL of the other channels but no joy.
    Reading the above, I assume that I have to re-tune the TV's on the RF2 each time I change the RF Channel. Time consuming eh?
    I'll try 68 and 21 as a kick off.
  7. theoldbill
    theoldbill
    Dec 27, 2003
    40
    Manchester
    +6
    Spot on advice!
    I didn't realise at first that you have to change the channel and then move down the menu or "Save settings" for it to change the output.
    Tried 21, retuned both TV's on the RF2 and it's now perfect. Happy, happy days.
    Just need to get hold of a second Sky+ remote now.
  8. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    check out ebay nice and cheap
