Sky+ Installation
Discussion in 'Sky Digital TV Forum' started by BruceG, Oct 14, 2003.
  1. BruceG
    BruceG
    Jan 4, 2002
    49
    9
    Bedfordshire, UK
    I'm thinking about having Sky+ installed (it's now a free sub for me). I've been having problems lately with freezing/pixellating/blocking on a few channels, and was wondering if the Sky+ installation would alleviate this, as I think the problem lies with LNB droop and the LNB will be replaced? (I'm assuming that the LNB will have be re-aligned).
    Does anyone know if the Sky ladder-monkeys replace the original cable run to the STB at the same time, or is it best getting a local specialist to do the install?
    Finally, I know it's not cricket, but can anyone PM me with the names of any satellite install companies they recommend in the North London/ Hertfodshire region?
    Cheers,
    Bruce
  2. pentode
    pentode
    Dec 17, 2002
    109
    West London, UK
    +4
    Had Sky+ installed last week :D (upgrade by Sky installers):
    Uses same dish & bracket, just new (quad) LNB
    Uses existing coax cable run to dish - one new cable run added
    Uses same Sky card
    Dish was not realigned - all signals at approx 70%
