Sky+ installation question
Discussion in 'Sky Digital TV Forum' started by southpaw, Oct 17, 2004.
  1. southpaw
    southpaw
    May 4, 2002
    310
    +5
    When Sky+ is installed what is changed?
    Is it just the LNB and the Sky Digi Box?
    Are the same cables used? And how long does it usually take?
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Depends what LNB you have in the first place.
    usually
    Change the LNB for a quad
    Run a 2nd cable to compliment your original
    Connect original cable & new cable to Sky+ box.
    Phone call to Sky to get Sky+ activated (no need for a new card)
    Depends on individual cases (cable routing etc) but they can do the physical stuff in about 1/2 hour. May take Sky a bit longer to send the update through dish to digibox (upto 24hrs).
  3. southpaw
    southpaw
    May 4, 2002
    310
    +5
    Is the 2nd cable for recording other channels while viewing?
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Yes
    The Sky+ digibox has two tuners.
  5. southpaw
    southpaw
    May 4, 2002
    310
    +5
    Does it involve more drilling or will both cables go through the same hole?
  6. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Depends how big the hole is in the first place.
    Just used slightly bigger drill bit on mine & went through the now expanded original hole with both cables.
  7. southpaw
    southpaw
    May 4, 2002
    310
    +5
    Thanks for your help.
    Just wanted to check as I'm having problems with my current box (see Sky Interactive problems thread) and think i need to upgrade to Sky+ now.
    Thanks again, very helpful.
  8. scussy
    scussy
    Oct 16, 2004
    130
    +8
    i will be getting sky + and a couple of extra boxes in the next couple of weeks, :clap:
    what would be the best way to set up my main system,using cables
    scarts,S-Video,optical, etc
    set-up
    SKY+,plasma 42",dvd recorder,vhs,AV receiver 5.1 surround and speakers,
    at the mo i am using gold scarts for my rear projection(40" tosh) with NTL
    now iam going for a plasma should i use better cable :suicide:
  9. quattro
    quattro
    Nov 30, 2003
    389
    Stafford
    +16
    Most definatley going by what the pro's say in the Plasma section and what i have done, My sky+ goes via a JS VGA/RGB converter, Dvd via conponent cable to make use of the progressive scan DVD, and then i have a scart going to quintro for Xbox and various other kit. Sky+ box is connected via optical to my DVD surround sound system and Quintro via phono cables, cables are Van Damme reds for component and VGA scarts are gold techlink i think.
    Quattro
