Sky+ installation question - existing dish
Discussion in 'Sky Digital TV Forum' started by Jules1975, Aug 17, 2005.
  1. Jules1975
    Jules1975
    We have moved house. Before moving I ordered Sky+ at the new house, it is being installed next week.
    When we moved in we found that the house already has a minidish and a cable into the lounge. No idea if this works but can't see why not.
    I wondered if anyone could suggest what the engineer will do? Will he install a brand new minidish and new cables and ignore what is already there? If so would I then end up with potentially two systems (if I buy a digibox on ebay or something)?
  2. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    He'll likely just replace the LNB for a quad LNB and run new cables but will leave the dish as it is - at least that's what happened when I got Sky+ installed.
    John
  3. jshaw_82
    jshaw_82
    Dec 13, 2004
    185
    Derby
    +3
    I had an existing dish (someone elses) when i had it installed, he took that off and fitted a new one...
  4. Jules1975
    Jules1975
    Presumably the dish itself belongs to Sky then does it? I understand the digibox belongs to the customer.
    My understanding is that with sky+ you get a quad LNB i.e. you can run four cables from the dish and that the Sky+ box uses two of these. How easy or difficult is it then to connect more cables to the other two outlets?
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    If you paid a subsidised price for the installation, the box and dish become your property after the first year.
    How easy or difficult it is to add two more cables really depends on how accessible the dish is, and on your own physical and technical capabilities. On most installations it's not the hardest job in the world.
  6. Jules1975
    Jules1975
    The dish is quite low down. I can get to it and I'm happy I would be able to sort out all the cabling. Regarding a third cable from the LNB, is it just a question of having the right kind of plug and plugging the cable in, or is it more technical than that?
  7. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Assuming that your dish has the requisite number of available outputs, all you need is some satellite-grade cable and some "F connectors". See here on how to wire them. Be sure to use self-amalgamating tape, not ordinary insulating tape ! :thumbsup:
  8. Jules1975
    Jules1975
    Excellent, thanks. I forsee a trip up a ladder very soon :D
