Sky Installation DIY?
Discussion in 'Sky Digital TV Forum' started by gozzy, Jul 1, 2001.
  1. gozzy
    gozzy
    Oct 22, 2000
    503
    Newcastle upon Tyne / UK
    +18
    I'm installing a friends sky digital system in his new house. I can get the dish lined up to get a good signal strength and a good signal quality,it wont lock on and the s/quality keeps going up and down! (keeps losing the s/q )
    The lock indicater shows, "Not Locked" mine system shows "OK"
    Does anybody know what I'm doing wrong???????
    Is there something i should be doing in the installers menu ????
    Any help gladly accepted.
    cu later
    johng
  2. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    sounds like it could be an obstruction .
    are there any near by trees or anything? . what cable are you using . i don't think that any old coax will do , you need proper sat cable
  3. KAO
    KAO
    I understand it can take up to a minute for the box to lock onto the satellite...
  4. gozzy
    gozzy
    Oct 22, 2000
    503
    +18
    The cable the proper stuff as its all the original from the old house. There's no obstructions either!
    Could be that I'm not giving it enough time to lock on, I thought there might be something I needed to do before it locked on.
    cu later
    johng
  5. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    how long as the cable been on the house. the cable has a limited life span . it could be that it has decayed to a point that you are killing the sig so it will not lock .
    just a thought
    one last point . are you defenate that the dish is pointing at the right satalite . if it is pointing at the old astra satalites then it will not lock but you will still get a signal
    i am not calling you stupid or anything it is just very easily done
    could just need to be left a few mins though :rolleyes:
