Sky+ input signal problem
Discussion in 'Sky Digital TV Forum' started by adevonbloke, Jul 5, 2005.
  1. adevonbloke
    adevonbloke
    Recently bought second hand Pace 3100 and installed all myself.
    Picking up sky channels fine and have installed raven quad lnb with new dish.
    Did signal test and input one shows good signal quality and strength. Input 2 shows no signal at all. Swapped cables around and still have good signal on Input one and no signal on Input two. so I guess LNB and dish OK
    Does this automatically mean there is a problem with the box or can dish/lnb be moved to get good signal at both inputs?
    If it can only be the box, any ideas what problem may be?
    Any help will be gratefully received.
  2. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    No signal on input 2 can often mean that the hard disk is on its way out.
    John
  3. JuzzyD
    JuzzyD
    Nov 18, 2004
    225
    28
    +24
    Could be a faulty harddrive - this is a classic symptom of a failed drive.
    Easy to replace though! (threads elsewhere)
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Well, easy if you have experience with PC hardware :)
  5. adevonbloke
    adevonbloke
    Thanks for the help guys.
    I take it there are no fuses inside that may cure this? Are you saying 99% certain to be hardrive. I just bought this off ebay so not sure if to ask for money back or do harddisk upgade that I was planning anyway.
  6. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    I'd go straight for the HD upgrade if I were you.
    John
  7. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It's not unusual for a hard drive which has been running continuously for a year or two to fail after it has been switched back on after being allowed to cool down.
    What happends is that one of the heads (which are tiny) gets stuck to the disk surface, and when the disk spins up again, it rips the head completely off the arm. If the drive is running noisy, it's a symptom of this.
    If you were contemplating a HDD upgrade, buy a hard disk and give it a go. If the fault turns out not to be the HDD, you have a drive ready for the next box you buy. The best drive for a Pace 3100 is the MAXTOR 160GB 5400RPM 2MB ATA133 D-MAX16 QuickVIEW 4R160L0 which you can get from Technoworld for £ 57.58 (Incl. VAT). This is a 5400 rpm drive especially made for PVR's and it runs nice and cool. :smashin:
  8. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,428
    2
    In a secret location with Jennifer Lawrence
    +9,124
    Before you go the route of hard drive change, why not give Sky a call.
    Had a problem recently with Signal 2 showing no signal and gave them a call and they fixed it over the phone. Something to do with rebooting the LNB etc? Can't remember exactly what they did but it cured the fault.
  9. nick270881
    nick270881
    Feb 21, 2005
    1,202
    HULL.......Born & Bred!!
    +134
    Input 2 does not always show up on the signal test screen first time!
    Try a double recording (assuming sky have activated the recording function for you) i.e. record two programmes at once, then check the signal screen!
  10. adevonbloke
    adevonbloke
    Thanks for your help guys, I will give the last couple suggestions a go. There is certainly no hardrive noise, it is very quiet so probably not that problem Nick. I have already ordered the Maxtor 160gb 5400 hardisk. I will call sky again and see what they come up with.
  11. adevonbloke
    adevonbloke
    Hi again,
    Want to say thanks Nick as last night I installed a new Maxtor 160gb hardrive and touch wood all is very fine and I can now see what I have been missing.
    I have another question from a mate who has the V2. He says it locks ups when watching recorded programs, but it does it at the same point every time. Do you think this is another hardrive problem as if it is I will do the same installation on his.
    Thanks again
