wullsy
Established Member
ok, this is driving me nuts !!
I've just bought a v1 Pace box second hand.
I've fitted a quad lnb and tested both feeds via an old digibox I have. Both work fine, with roughly 75% signal quality.
If I connect them both to my Sky+ box, Input 1 is still 75% signal quality, but input 2 has no signal strength, nor any quality. I've tried swapping the cables around, so that tuner 2 is getting feed 1 etc, with the same results.
I've tried a full factory reset (Services 4 01 select) and left the box off for a bit.
If I try and tape something from Sky+ via the planner, it tapes fine, as long as I am currently on that channel. If I'm not, it doesn't tape. So, this suggests to me that :
1. Dish,lnb and connectors are ok cause I wouldn't get a signal on my old digibox otherwise.
2. My Sky+ subscription has been activated or I wouldn't be able to tape at all.
so, anyone any ideas as to what I can try next ??
