Sky+ Input 2 not locked
Discussion in 'Sky Digital TV Forum' started by Madgpol, Feb 3, 2005.
  1. Madgpol
    Madgpol
    Nov 26, 2003
    26
    Sky + Input 2 not locked
    Guys,
    any help gratefully received.
    As the header suggests input 2 is not locked. As a result I have no recording facilities. Sky itself works fine and I can view all channels etc. I've tried numerous housekeepings (This used to solve issue) without any success. I've ordered a 160gb harddrive with the intention of an upgrade.
    o you think this will solve the issue ?
    Thanks in advance
    Jason
  2. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    input 2 not locked and no recording is asign of a harddisk failure so a new drive should solve the problem
  3. nheather
    nheather
    Oct 6, 2004
    17,471
    167
    Horsham, West Sussex
    +6,830
    I agree, when this happened to me it was the hard disk.
    This is what I experienced:
    Input 2 not locked
    Do a system reset
    Input 2 IS locked - all looks fine
    Attempt to record or view anything on the hard disk
    Attempt fails
    Check status - input 2 is NOT locked
    Replace hard disk - all is fine
    Cheers,
    Nigel
  4. Madgpol
    Madgpol
    Nov 26, 2003
    26
    Fitted a 200Gb harddrive maxtor 6B200P0 and all functions are working as expected. Thanks for the confirmation guys that the hardrive was the issue
    Regards
    Jason
  5. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    Input 2 showing 'not locked' can be due to hard disk failure but isn't the only possible cause. I would hate to think someone would dive in and replace the hard disk without making some simple checks first (cables, LNB etc.)
    Before you buy a new HDD, try the 'Factory Reset'. This will re-format the HDD. This is at your own risk - all saved programmes will be lost! :eek:
    Switch off at mains
    Hold L&R navigation buttons whilst switching mains back on - hold for around 30 seconds - the green 'play' light will come on.
    Press 'select'
    The play light will rotate clockwise - upto 3 minutes.
    The box will go to standby
    Leave for at least 2 minutes while the HDD re-formats.
    Again, This is at your own risk - all saved programmes will be lost!
    A. Dork
  6. highlander_777
    highlander_777
    Apr 4, 2004
    216
    I have the same issue but I have the new SKY + 160 Box. I have only had this box for a couple of months. Seems a bit early for a failure
    I have re-sitted all the cables again. The signal 2 did go up to about 80% but when I check this morning it was 0% with the unlocked message
    Call Sky on Sat and they said someone can be out this Friday......Does anyone know what the SLA is with SKY?. As far as I am concerned the box is faulty and I am paying for a service that I am not getting
    :lease:
  7. Russ_64
    Russ_64
    Jan 20, 2005
    249
    2
    London
    +96
    I have the same problem with my "new" Sky+ 160 box (Thomson).
    My first box was replaced within a week after I complained thinking it was a faulty box. But my current box does the same from time to time, rebooting (power off) usually brings the 2nd input back.
    I have not yet had any problems viewing saved programs nor recording - I have it set to record a series every day, so I have concluded that although it may show Not Locked it seems to "switch" itself on when needed (?)
    :confused:
  8. bingo99
    bingo99
    Apr 14, 2005
    2
    I recently had the same problem, it turned out to be a loose jumper on the drive
    I replaced it with the one from the 40gb drive and everything is working fine now
    Hope this helps
