Sky+ in multiroom?
Discussion in 'Sky Digital TV Forum' started by Marvt74, Aug 9, 2005.
  1. Marvt74
    Marvt74
    Feb 13, 2005
    669
    28
    Manchester
    +26
    Since it only seems to be an extra £10 a month nowadays i'm thinking of getting it for my bedroom.
    Is there any chance of getting sky+ (initial subscription + box downstairs is Sky+) in the second room as does the sky dish have 2 lnb's or would the second room only be able to have standard sky.
    It says its £49 for a second box incl installation which i thought seemed cheap aswell since lots of boxes seem to sell for more than that anyway
  2. KevinWood
    KevinWood
    Dec 9, 2002
    102
    19
    Stirling
    Your Satellite dish will probably have a Quad LNB on it already, so the just use the two spare (your existing + sub will be using 2) to connect another sky+ box in the other room. That's how it was for me when we put sky+ in the living room, then a second sky+ box in our sons bedroom.
    Cheers.
  3. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
