Sky in another room via HDMI
Discussion in 'Sky Digital TV Forum' started by jmnathan, Jun 24, 2015.
  1. jmnathan
    jmnathan
    Oct 21, 2011
    14
    Hi all. I'm after a bit of advice regarding my sky setup. I currently have it connected up to my main TV set via HDMI and make use of the output to send the signal through the rest of the house and control it from my bedroom using an eye. I'm looking to split my lounge in two and will basically end up with the box in a different room (ie no longer in the lounge) to the main TV, albeit only a wall apart. I can, relatively easily, still connect it using HDMI, but what do I need to do to be able to control the box from my lounge? I am assuming the eye is a non starter as it works off the output via coax and not the HDMI.
    TIA
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
