I can't find the answer i'm looking for so hopefully someone here will be able to help, as i am absolutely rubbish with Sky!
In our new house we have had Sky+ installed which feeds into the lounge. The dish has 4 outputs on it, 2 of which are used and go to the Sky+ box in the lounge.
We have a normal aerial which feeds the bedroom, lounge and conservatory via the loft but gets terrible reception, hence the Sky. There are wall plates in each room.
I want to be able to get Sky+ in the bedroom and conservatory but am not bothered about having to watch the same thing as the lounge, but i would like to install magic eyes or similar to be able to change Sky+ channel and set recordings etc if possible.
I have run a normal aerial cable from the RF output on the Sky+ box to the Tv in the conservatory to test the signal and it worked fine, but this cable was just run through on the floor to test.
Is the best way to get Sky+ in the other rooms: -
A) Run an aerial cable up to the loft into the splitter, which will then feed the wallplates in the bedroom and conservatory. Then all i need is a magic eye between the wall and tv in each room
or
B) Could i run a output from the dish to the loft then get the signal to the wallplates via the exiting aerial cable already there?
or
C) Just get some scart wireless receivers and transmitter that i've seen on 'the auction site'
Any help would be really appreciated as i really don't know what is achievable
or
or
