Sky+, image not central?
Discussion in 'Sky Digital TV Forum' started by spook, Jun 14, 2004.
  1. spook
    spook
    May 18, 2004
    157
    Hi all, got my Sky+ installed yesterday, very impressed overall, just one small problem, the image is a fair bit off to the left?
    not so far as to see black on the right side but definately not centred properly, I have used 3 different tv sets through scart and rf and same on all 3, so definately sky+ problem.
    there is no option to change this in the standard consumer menu's, I would imagine theres an engineers menu somewhere to set this up, anyone know how to call this up?
    Pace Sky+ box, model no: 2.057C2
    cheers spook
  2. scooby do
    scooby do
    Dec 11, 2002
    2,032
    48
    +91
    Guess you are outputting via RGB, many TV's suffer from RGB shift, some allow you to center the screen for RGB sources via normal user menu other require service menu intervention (both on the TV). Does the skybox output Svideo you could try this.
