  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
sky + how ???????
Discussion in 'Digital TV & Video Players & Recorders' started by jonthebarber, Nov 24, 2003.
Tags:
  1. jonthebarber
    jonthebarber
    how do you change the harddrive in the sky + box ? mine is over 18 months old the were instructions in a "mag" but i don`t know which one and if so does any one know where i can get a reprint/back copy of it ? cheers .
    jon.
  2. jont
    jont
    Apr 8, 2002
    3,868
    near Aylesbury
    +394
    Switch off sky+, unscrew the case with a 'security torx' bit, unscrew hard drive mounting bracket, pull off HD power cable, pull off HD ribbon cable, take out HD ... put in new HD and reverse procedure ...
    Sky+ keeps its system in ROM so will take a blank drive inserted out of the box (unlike a tivo ;-)) and format it itself ...
    Maxtor DiamondMax (fluid bearing) models are silent and go up to 120Gb ...
    Jon
  3. jonthebarber
    jonthebarber
    top bloke ! thanks for your help !
  4. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    Are 120GB drives the max size for Sky+ ?
  5. philipb
    philipb
    Mar 6, 2002
    1,985
    63
    Swindon
    +132
    You can put in a 160GB, but the box will only recognise 137 GB. That's the maximum. I didn't think the extra 17GB was worth the extra cost of going to a 160 drive as opposed to a 120.
    since I upgraded the box has worked fine, but I notice that the fan is on all the time - even in standby. Sky+ is now noisier than my HCPC which i spent a lot on to make it quiet:(
  6. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    thanks for the info
