Sky+ How many aerial cables from the dish?
Discussion in 'Sky Digital TV Forum' started by [email protected], Oct 12, 2001.
  1. rob@rar.org.uk
    [email protected]
    Apr 29, 2001
    343
    16
    Hampton, Southwest London
    I'm thinking about Sky+ but I don't want to run another cable into my living room (exisiting cable is under floorboards to keep GF happy). How many cables does the Sky+ box require? As it has two tuners, does it need two seperate feeds from the dish?
    Regards
    Rob
  2. mart.stokes
    mart.stokes
    Yes. Sorry :( but it will be worth it.
  3. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    SKY installers I believe are using twin cables in one sheath.
    With a little effort I guess you could thread the new cable through the existing holes(May need widening a little) without the need for major furniture upheavel :)
  4. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    My sky+ was installed(by sky)with separate cables.
