Sky + - How do I extend the arial cable
Discussion in 'Sky Digital TV Forum' started by baldie, Jul 3, 2004.
  1. baldie
    baldie
    Jun 29, 2004
    52
    Morning,
    Had Sky + installed earlier this week, asked engineer to give us a long arial cable as I was going to relocate the box onto a shelf on the wall, however, I have just been down to move the box and found that he has installed a long cable for Input 2 but input 1 is the same length cable as I had before. Anyone know how and what I need to buy to extend the cable?
  2. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    Morning Baldie!
    Easy job! You will need a couple of 'F' connectors, an inline 'back to back' connector and an appropriate length of cable of course.
    Read this tutorial http://www.satcure.co.uk/tech/fconn.htm on how to fit an 'F' connector and all will become clear.
    Hope this helps. :)
    A. Dork
  3. baldie
    baldie
    Jun 29, 2004
    52
    Cheers Arthur,
    Any ideas where I can get these F conectors from on the high street? Need to get the job done today, rather than waiting for them to arrive in the post.
  4. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    +324
    Any TV repair shop (if you can find one left!) or as a last resort Maplin. They are only around 10p each but Maplin will probably charge a quid! Good luck!
    A. Dork
