kierangray1982
Hello,
I've recently had Sky Plus installed, at the same time as a digital aerial ( new house), so I have taken the opportunity to have sky distributed around the house using the existing coaxial wiring.
The current set up is this:
EXTERNAL AERIAL --> SKY BOX ( external wire running outside the house into sky box)
RF OUT 2 ( carrying analogue signal +sky) --> Existing aerial plate in wall
Aerial plate in wall --> loft
Loft --> to bedroom and dining room
SO with this set up, sky exists in the living room, and is distributed to dining room and bedroom on channel 8 ( RF out - 68) , magic eye in each room controls box.
So here is the question.
I "hate" the black cable running along the house, and into the living room, from the aerial. As there is only one "aerial plate" in the living room, is it possible to have that cable bring the aerial signal down from the house, and also carry the sky signal up at the same time?
Basically, i dont want the aerial cable running around the front of the house, but instead take it into the loft, and then do something up there?
SOrry if this isnt a good explantion
Kieran
Kieran
