Sky + hidden Menu
Discussion in 'Sky Digital TV Forum' started by zhukov2027, Jul 7, 2003.
  1. zhukov2027
    zhukov2027
    How do I get the hidden Menus up to install a new HD.
    Also Can I use a HD that has been setup on my pc will it reconfigure the drive in sky?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    Hidden Menu
    Services
    4
    Select
    Full System Reset to prep the HD.
    I'm not sure but I see no reason for a HD with a previous format not to be wiped and initialised for SKY+ after a system reset.
  3. zhukov2027
    zhukov2027
    Thanks.
    the old 40gig drive can I put it back in at alter date to get the data off or put on to pc.?
  4. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    I wouldn't like to say, there may have been OS changes after the original drive was removed which might make it uncoperative with SKY+ unless you did a full system reset on it.
    I'm sure there must be someone in the forum who has actually tried this:)
    The data on the drive is the original encrypted bitstream so while you might be able to access the data there is nothing you can really do with it.
  5. zhukov2027
    zhukov2027
    If I take out the old 40 gig and put back in at a later date will it format all my data that is on the drive?
    As dont want to lose certain films till my DVD recorder turns up.
  6. jont
    jont
    Apr 8, 2002
    4,197
    near Aylesbury
    +528
    AFAIK you can take out a drive, put in anew one, take it out and put the old one back in and still be able to watch your old programmes ...
    Jon
  7. Doctorb
    Doctorb
    Jan 31, 2003
    154
    To be honest,if your going to start changing the HD you might as well ditch sky+,save a tenner a month and get a recordable dvd player.The standard HD is more than enough plus most channels seem to repeat things quite often.
  8. zhukov2027
    zhukov2027
    Just brought the panny e60 no hdd
    no need for it with sky +
