Sky+ Hidden Commands
Discussion in 'Sky Digital TV Forum' started by phanco, Aug 31, 2004.
  1. phanco
    phanco
    Feb 18, 2004
    633
    Edinburgh
    +16
    I'm just about to embark on upgrading my V1 sky box (80Gb Maxtor on order - thought I'd start simple and cheap @ £30).
    Is it possible to get a 'sticky' with all the hidden menu commands (Full system reset etc) that might be useful. It is difficult to find individual commands in the other threads ...
    Anyone out there able to provide a list and a brief para about what the command does ?
  2. phanco
    phanco
    Feb 18, 2004
    633
    Edinburgh
    +16
    no Takers ?
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    A Full System Reset wipes the hard drive and series link data leaving the hard drive in a virgin state, can fix some problems but is a last resort since you lose all recordings.
    I personally believe that doing this whenever the opportunity presents itself is no bad thing but I am still on a basic 40gig drive so can on occasion can empty it through normal viewing.
    Hummers website covers many upgrade issues.
  4. Fernsehman
    Fernsehman
    With the latest software, I understand you can now limit the "reset" to simply updating the EPG. It's in the "hidden" menu.
    [services] 401 [select]
  5. bobbles
    bobbles
    if you are ugrading a V1 do not use the planner rebuild it can lead to the 17min bug
  6. phanco
    phanco
    Feb 18, 2004
    633
    Edinburgh
    +16
    If I do a planner rebuild on a virgin disk, I wont get the 17min bug (or will I)...
    The again, this would probably be pointless on a vigin disk as I will be doing a full reset anyway...
