Sky Hi-Def
Discussion in 'Sky Digital TV Forum' started by Astaroth, May 13, 2005.
  1. Astaroth
    Astaroth
    Jun 22, 2004
    3,653
    2
    London
    +883
    Sorry if this has been asked before but I couldnt find it on a search...
    Has Sky announced if for high def you will need to change just your sky box or if you will also need to have a new form of LNB? Will it require one or two feeds from the LNB or will that depend on if you have the Sky+ or non-sky+ type version?
    Many thanks
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    There will be a new SKY+ variant which will be used for High Def, it will also handle the normal standard definition channels. There has been no word of a basic HD box without recording facilities which is perhaps because there is no practical way for the average viewer to record HD at this time.
    No change of LNB is expected nor realigning of the dish but as always until the product is launched there are still grey areas:)
