SKY+ help
Discussion in 'Sky Digital TV Forum' started by nickcat65, Sep 8, 2004.
  1. nickcat65
    nickcat65
    Sep 8, 2004
    3
    Can anyone tell me - if i buy a sky+ box and use my existing sky card will
    it work ie will i get the same channels etc and will the optical out work.
    Obviously the 2 channels bit won't but will it record from the channel your watching ??
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Your card will need to be married to the SKY+ just as it would to a normal digibox to get all the channels unless of course you don't subscriber to premium content.
    Without the SKY+ service being activated and paid for then you can not use any of the recording features of SKY+ but the optical output works regardless.
