Sky HDTV to only support HDMI/DVI NOT component!
Discussion in 'Sky Digital TV Forum' started by GadgetObsessed, Dec 3, 2004.
  1. GadgetObsessed
    GadgetObsessed
    Jul 6, 2001
    2,130
    116
    +911
    According to news on HomeCinemaChoice Sky are saying they will ONLY support HDTV via HDCP compliant HDMI/DVI. So displays with only component inputs will not be able to display Sky's HDTV at all - even if they can support 720/1080
    http://www.homecinemachoice.com/cgi-bin/shownews.php?id=7231
    I suppose it makes sense that Sky want to protect their content. Does rule out Sky HDTV for many existing plasma/lcd owners though.
  2. Flashman
    Flashman
    Dec 3, 2002
    353
    Swindon, Wilts
    +11
    Yeah, wonderful.....My Tosh 32WL46 is HD compatible through it's component inputs and I thought I would be okay when Sky upgraded......Looks like that's not going to happen.
    Still, in two years time I may have relegated it to the bedroom by then, in place of something hopefully a bit more future proof!
  3. roberte
    roberte
    Nov 14, 2004
    177
    +10
    this leaves only a few lcds compatable at present therefore?
    sharp, hitachi ,is this right?
  4. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Toshiba 32WL48 has HDMI.
  5. roberte
    roberte
    Nov 14, 2004
    177
    +10
    any others?
  6. CarnalSins
    CarnalSins
    Philips 32pf9986
  7. jimg
    jimg
    Jul 4, 2004
    826
    +58
    The Sharp Aquos screens with DVI should be OK
  8. PhilB1234
    PhilB1234
    I'm disappointed as I have a new Tosh 30WL46 in transit to me at the moment! They even ran promotions in FHM boasting about it's HDTV compatibility, but it's non-HDCP compliant so it'll be impossible!
    The helpdesk asked me to call back to speak to the workshop to see if the HDCP can be 'enabled' as the specs describe it as 'not enabled'... Not holding my breath....
    Surely a third party could make a device to remove HDCP? Any ideas of how to get round this?
  9. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Loewe Xelos SL and Spheros support both 1080i and 720p without compromise.
    Hopefully the Sky boxes will be compatible with the Sharp 1080i input - some sources are not. I guess that is up to Sharp and Sky to work out between them.
    Some displays also give a bordered screen when presented with some resolutions/timings, ie 720p - 1280x720 displayed on a 1366x768 screen. I think someone mentioned that this was the case with the Philips when presented a 720p picture via DVI but maybe they didn't find any zoom mode.
    Something to note, the resolution used, 720p, 1080i is at the broadcasters discretion, with 720p being the dominent format. With HD boxes that already exist overseas, it is not possible to convert between the two formats within the box. So if the picture is broadcast in 720p, you get 720p, if its broadcast in 1080i, you get 1080i. It is possible that this will be the case with Sky.
    As for 'cracking' HDCP. Don't hold your breadth. The encryption is performed at chip level by the source MPEG decoder and decrypted by the display again at chip level. If the public decryption key of the display is compromised, ie hacked, then the key will be held in a blacklist that is broadcast with transmissions or stored on future software - ie DVD's. Short of replacing the MPEG encoding chip with HDCP free versions, HDCP remains extremely secure especially in such a controlled hardware environment such as Sky.
    -Ian
  10. cerebros
    cerebros
    Dec 27, 2002
    1,294
    48
    Leicester
    +29
    To be accurate, they say "vast majority". As they've yet to state what content this will apply to it may not be the absolute disaster people are treating it as, although obviously it's disappointing.
  11. Quickbeam
    Quickbeam
    The output is switchable between 720p and 1080i on US HD STBs; I believe this is a mandatory feature. This is essential as many displays will not accept 720p, which would mean no picture on FOX, ABC and ESPN broadcasts if only native output was supported.
    Sky boxes will almost certainly be 720p/1080i switchable. 768p may well be supported too as it is such a common display resolution.
  12. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    Im glad the be wrong about that.
  13. jgrg
    jgrg
    Oct 19, 2004
    559
    28
    Cambridge
    +36
    HDCP only works on digital connections, and the 30WL46 doesn't have any (DVI or HDMI) as far as I know.
    You will not be able to buy a legal device that removes HDCP. Devices with digital and analog inputs must disable any analog video outputs when playing a HDCP compliant input.
    James
  14. gnudi
    gnudi
    30WL46 has a dvi input but sadly its non HDCP enabled... More like a PC input only (1280x768 over 1280x720 resolution tends to confirm that choice...)
  15. PhilB1234
    PhilB1234
    Hi jgrg
    I fear you're right about removing HDCP... However the set definitely does have a DVI input as I checked that thoroughly as I have a scaler that I am going to use with it over DVI. Still no use for Sky-HD though!
  16. roberte
    roberte
    Nov 14, 2004
    177
    +10
    Does Anyone Know The Following About Telewest
    Are They Going Hd Tv As Well Or Is Sky The Only Provider Thats Going Hdtv /
  17. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    I would guess that HD is the future, that is until UHD becomes available ;)
  18. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    I think there'll be other formats inbetween that. Or something we haven't concidered. 3d tv is being tested apparantly.
  19. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    Ahhh but Ian - if you listen to popular music you should know that it's *CHILDREN* that are our future... ;)
    ...and I bet they all say "...and what a pigs arse you oldies all made of getting a decent TV standard set up." :laugh:
    Phil
  20. jgrg
    jgrg
    Oct 19, 2004
    559
    28
    Cambridge
    +36
    Since cable operators have been squeezing the bandwidth given to TV in favour of broadband internet, I think it is unlikely that they could give enough bandwidth to support HDTV.
    In theory the amount of data you can get down a cable, or rather optical fibre, is really huge. But it requires optical fibre right into the home, which none of the current cable providers in the UK have. And the UK cable companies are still in debt due to the cost of their initial installation. There are trials of fibre into the home in the US. Until then Sky will be in a very strong position, maybe rivalled only via the BBC's proposed "Freesat" service.
    James
  21. roberte
    roberte
    Nov 14, 2004
    177
    +10
    If telewest dont respond to this i think we could be seeing a major final nail in their coffin cos by 2006(MAYBE EVEN BY THE SUMMER OF 2005) i am sure that new lcd tv's will have hdcp compliance .
    People will want to get the most from these televisions ,and if they cant at telewest they will Change to sky.
    I THINK THEY BETTER GET THEIR ARSES IN GEAR !!!!
