I'm sure this is quite obvious to most of you, but is the Sky HDMI cable that come with SkyQ sufficient for UHD 4k use?
I am happy to replace with a better cable if its worth doing? I noticed people are recommending the Amazon Basic ones, quite i'd have thought are pretty much the same as the supplied Sky cable?
If it helps, mine is used for video only, as my amplifier takes care of the audio signal.
Cheers.
Cheers.
