Sky+ HDD upgrade question
Discussion in 'Sky Digital TV Forum' started by guyb, Jan 17, 2005.
  1. guyb
    guyb
    May 20, 2001
    657
    Leamington Spa
    +5
    Hi All
    Is it possible to carefully install a new HDD in Sky+ without visiblely messing up the warranty so if something goes wrong I could put back in the 40gb drive back in and give Sky a ring without them knowing I opened it up?
    Guy
  2. cebs_uk
    cebs_uk
    Jan 25, 2004
    2,537
    Manchester
    +406
    If you are carefully or replace the screws with new ones that show no damage from what I can tell looking at mine there does not seem to be any way to tell so just be careful I guess.
    Cebs
  3. guyb
    guyb
    May 20, 2001
    657
    Leamington Spa
    +5
    Thanks for the answer. I was hoping that would be the case. I have only just got Sky+ and didn't want to lose the warranty because it seems a bit flakey to say the least (mine freezes all the time!)
    guyb
