Quantcast
Sky+HD
cheetahdavie
I don't have a TV that is suitable for HD..my TV is a Ferguson bought in 1981..its given great service and still gives great pictures/sound.
I "bought a Sky+HD" box because the "box"was free..setup was free and I received £100 M&S vouchers..a "no brainer" over 12months.
Problem..
I see the "box" advertised as being able to "record 2 programmes whilst watching a third"
To night..a real test..
Me Chelsea&Spurs..video. Missus..a prog on IT V..then the Mentalist on "Fiver" plus the Alphas?? for her. Any how
set video for footie and Mentalist..and then received the message on screen that Two programmes where about to start recording..which one did I wish to Delete..being brave I deleted the footie??
Question..does this box record 2 whilst watching a third..Should I have ignored the screen warning an let it carry on or is the advertising wrong it doesnt record 2 whilst watching a third??:lease::lesson:
Stevenage Neil
It will allow you to record two programmes whilst watching a third previously recorded programme.
tut_gareth
The advertising is slightly misleading, but if you read between the lines, you can record 2 channels at the same time but you can only watch something that you have already recorded or something from Anytime or Anytime+
961
Another point to remember that may not be apparent is that the box can only ever receive two programmes at once. So...
If you have the box set to record two programmes then you cannot be watching a third at the same time or, more importantly, have it switched on to a third channel at the time the programmes are due to record
If this is the case the box will ask if you want to continue to watch the programme that is currently showing and, if so, which recording you wish to cancel. If you are actually watching the screen you can obviously choose. But if, for example, you have switched the tv off but left the box on, you won't see that choice offered, and the box will fail to record one of the recordings
So it's important either to switch the box into stand by or make sure it is set to one of the channels that you plan to record later
davemurgatroyd2
Not true the box will usually (and should) switch away from the "viewed" channel if there is no input from the remote and allow both recordings.
pakolainen
That's cleared a lot up for me. But agree with last comment. It doesn't switch the channel if box is left on.
davemurgatroyd2
Certainly doesn't always happen with this one
Always does if box in standby
In ten years of Sky+ and Sky HD in two rooms (and with six different boxes) I have never lost a recording in this way and the boxes are in continual use over 12 hours a day with numerous set double recordings. The only recordings I have seen lost by this are down to my 90 year old father using the remote to get rid of the on screen message usually by pressing backup which will cancel the recording that is listed as not already starting to record.
961
Unless you can come up with another answer we must agree to differ
If I leave the box on to, for example, sky news, with two recordings set for later at same time, one will always fail as "clashed"
If your box has different settings to avoid this, please tell
(We only have one box)
anfukf
I could have written the same post except my father is 81 :D.
2 boxes and they always switch channels if there would be a clash unless he interferes..
logiciel
My experience is closer to yours, and in general the behaviour of Sky machines varies from one to the next.
We can only tell different settings though if we know what yours are.
961
Well my settings are all basically set to auto with things like add to start and end of recording. Anytime recording is on, but the hard drive is not set to run all the time, so that the box does not record so that I can for example run back 30 minutes if I start to watch a programme half way through
I may be missing something, but I don't see what age has to do with it. (Unless we are talking Thomson boxes)
davemurgatroyd2
Anytime set to on
Instant rewind 60 mins
Add to start and end both set to automatic.
Same settings on all six boxes (except Mk1 Pace Sky+ boxes - no Anytime) and I am still using a Thomson Sky+ HD box as a FTA PVR with old blue card plus two Amstrad DRX890's with subs cards.
cheetahdavie
Thanks for all the replies to my original query.
There is an awful lot for me to consider..I as a novice..anything other than resetting the circuit breaker on the main box is too technical for me..
again thank you
Similar threads
Trending threads
