Sky + HD
Eddieboy
Hi there everyone.
just wondering if you could give me some advice.
i was wanting to get my sky on a second tv but am having a slight bit of difficulty.
the problem seems to be the coax cable. it is going to need to be about 20 metres long to take it from the sky box in the living room to the bedroom. to test i had a 10m bit of cable to the tv and i could not pick up the sky picture. i moved the telly to the living room and used a 1m cable and it worked fine.
could it be the length on the cable (it is brand new)
or are there different types of coax cable and i have the wrong one.
thanks in advance and sorry if this is in the wrong section.
Ed.
Johnbyte
Established Member
The longer the cable, the more it will degrade the signal from your Sky box. Firstly, do you have twin screened coax? It has a copper braid AND a foil covering under the outer insulation. This will give you the best chance of a signal; so-called low loss coax may not be up to the job. If you already have twin screened cable, you may need to install an aerial amplifier at the Sky end, to overcome the cable loss. Make sure you have the RF2 power option set to 'off'.
logiciel
Hi, welcome to AVF, and your question about Sky HD is fine in the Sky HD sub-forum.
The thread header doesn't tell us much about what the question is though.
This subject has been covered many times in the forum, but it's early for you to use the Search function as yet.
A better way than the cable system in my opinion is with a pair of wireless videosenders.
HTH - Logiciel
Is 8K TV dead? Philips OLED+907, Pioneer LX505 AVR plus B&W 700 S3 Reviews & Visit + AV/HiFi News
