Sky HD " zooming " problem on Samsung UE55F8000
Discussion in 'Sky Digital TV Forum' started by danspree, Aug 23, 2013.
  1. danspree
    danspree
    Apr 3, 2012
    20
    3
    Hi All,
    I am looking for some help on a problem with a sky set-up.
    The sky is connected to several TV's in the house via HDMI / splitter / CAT 5 , all of which are ok except for the
    Samsung UE55F8000 .
    What happens is, on all channels quite often, when you select a channel the image is zoomed in to the point that the CH5 HD logo for example fills the screen.
    If you go onto the programme guide screen, then back to channel it is ok..until it happens again.
    Both sky pic options are set to 16:9, and the samsung options set to 16:9 too.
    Any idea's?
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    Given that all your other TV's are OK, this is clearly not a Sky problem, so should have been posted in the TV section.
    Double check your Samsung settings, as it sounds as if it's set in one of the zoom modes to eliminate black bars.
  3. simon194
    simon194
    Nov 29, 2006
    1,787
    63
    +218
    These picture settings on the box are only applicable to the SCART and RF outputs not HDMI. So a TG says it may be a setting on the TV or possibly as fault with the TV itself.
  4. iNspectorgadJet
    iNspectorgadJet
    Jun 29, 2005
    2,161
    14
    116
    Waterlooville
    +848
    I would also set your picture size on your tv set to screen fit instead of 16:9. What have you got the hd resolution on the sky box set to? Have you tried it on a fixed setting rather than auto?
  5. danspree
    danspree
    Apr 3, 2012
    20
    3
    Thanks for the help all.
    Went back out to have a look/ try different TV's in different spots, (move 1 tv from 1 room to the other) and found that the zooming problem was even happening on an old CRT set, and not only via ethernet, it was doing it via RF.
    So at the moment, feel skybox is to blame, if not that, maybe the HDMI splitter.
    Very odd.
  6. GTunney
    GTunney
    Jun 29, 2011
    1,337
    116
    Newcastle UK
    +607
    What's the output setting set at on the sky box? If auto try setting to just 720p
  7. danspree
    danspree
    Apr 3, 2012
    20
    3
    was set to 1080i , rather than 720.
  8. neilball
    neilball
    Jan 7, 2005
    2,910
    Scottish Borders
    +641
    It cannot be your Sky box as otherwise all TVs showing Sky would be affected at the same time, not just. single location.
    Edit - sorry, just re-read your last post where you said it happened on a CRT via RF, so clearly that has to be the Sky box. Are you sure you have the video settings set to 16:9 on your second/RF2 output?
  9. danspree
    danspree
    Apr 3, 2012
    20
    3
    Other TV's have had same problem in all locations in house- even on old CRT set via RF.
    Will be a case of trial and error i think!
