Sky+HD with Triax DDU
andyd55
Good evening folks,
I am moving into a new build property next month and am currently planning what way to flood the rooms with TV signals etc.
I would prefer to have the Sky feed straight from the SAT into the roof space to avoid the 'sky engineer' running a great big cable down the front of my nice new house.
From researching I believe a Triax DDU would then allow me to feed this down to the main living room, where the builder has run two aerial cables down. I believe I can feed both signals for sky+HD down one line and the RF2 output up the other allowing all the other TVs to then have control using the SKY EYE system.
My question is, all 8x outputs will be used in the loft and the builder has already run them cables. However we would like a feed into the kitchen and also the sun room. Is there an extension box or something that is compatable with the Triax DDU which would allow me to further split an output from the loft box and share it between another two rooms?
kevkbuk
Gonna need a much, much, much longer cable to run from the sat, and 'Sky Engineers' don't like lofts.
MartinPickering
Good point from Kev. You'll have to install the 4 LNB cables, and the two drop-leads yourself, before the Sky installer arrives to hook them up to the LNB.
logiciel
Hi.
M P was referring to this, that's meant to be helpful in getting relevant replies to specific topics:
http://www.avforums.com/forums/sate...ere-youll-get-better-answers-right-forum.html
The thread that he linked to confirms that one cable carries one satellite signal down, and terrestrial and radio if required, while the second carries another satellite signal but also takes the Sky RF output back the other way.
M P: kevkbuk made two good points.
I trust that you also got the first one, about the very long cable.
More in that vein, especially now from kevkbuk, will always be welcome.
:thumbsup::clap:
andyd55
How so? I am planning on using the existing wiring? And I am happy to wire it in the loft and have it ready to pass out to sky engineer when he drills a hole?!
logiciel
It's more that Sky don't allow their staff to enter lofts, and yet they have to do all the work, including all the cabling, in order for the warranty on the installation to be valid.
To get around that condition of your contract with them, you'll have to negotiate something different, well in advance of the installation date.
andyd55
Yeah I have heard this about sky, we have proper fold down steps to loft and its all floored in new house but still I am more than happy to wire the loft bit in. However I see your point about them having to do all the work.
MartinPickering
As it's floored, there should be no objection to the Sky installer working in there. However, they have other rules about drilling into soffits, barge boards and roof spaces, so you might, at the very least, have to drill the holes. As stated, this is something you should negotiate in advance, and be sure to do so in writing, so you have proof.
I doubt that cable length will be a problem as the overall length probably won't be much longer than for "a standard" installation.
logiciel
logiciel
I was so much hoping that an explanation would not be necessary.:(:clap:
still applies, and I hope posters will let you keep them subtle.
logiciel
The differences between the labels Sat2 and LNB2 are that S is not L, a is not N, and t is not B.
The functions on the sockets are the same but that wasn't the topic of discussion.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
