Sky HD with Themescene H30 projector
Discussion in 'Sky Digital TV Forum' started by trainspotter, Mar 28, 2006.
  1. trainspotter
    trainspotter
    Dec 14, 2003
    148
    I currently have Sky+ connected up to my Optoma Themescene H30 projector, The H30 is not listed as "HD Ready".
    So, as I aim to upgrade fully to HD over the next couple of years, will I notice any improvement by replacing my Sky+ for Sky HD without replacing my projector?
    thanks for any advice
  2. indiejones
    indiejones
    May 2, 2004
    158
    +20
    I have the H30 and it will ouput HD 720/768p
  3. trainspotter
    trainspotter
    Dec 14, 2003
    148
    Thanks.
    I am a bit of a ludditte sometimes :blush:
    so what does your posting mean please :)
  4. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    it doesnt have to carry the HD Ready Logo to be able to play HD material, it mainly needs to be a 720p or higher resolution.....however it also will need to be HDCP compliant (a form of copyprotection, if the port on the projector isnt HDCP then the Sky box wont output to it) if you wish to use the HDMI connection.....
    my Infocus 7205 isnt 'HD Ready' but will play HDMI from the Sky box as it has 720p native resolution and the M1 port which i already have an HDMI adaptor for is HDCP compliant....hurrah
  5. kentlad
    kentlad
    Oct 28, 2003
    Trouble is I also have this projector and it does not have the required DVI or HDMI inputs required for Sky HD.
    Only HD available via component which I understand Sky HD will not work due to the HDCP issues.
    Kentlad
  6. sweezely
    sweezely
    Sep 14, 2004
    70
    It should work for the near future at least, as the first-gen HD box has component outputs for people with older HD equipment. It's unclear as to how long Sky will output on them, though.
  7. indiejones
    indiejones
    May 2, 2004
    158
    +20
    sweezely is correct I have spoken to the SKY reps at the Home Automation Show at NEC Birmingham and they confirmed this HD will output via component, from my understanding of this SKY needs to have as many users as possible on HD SKY by including component input they would widen there sales, as for the future of HDCP I dont know if SKY will be able to stop this but from what I was told they will be producing newer boxes without component output who knows by then there might be a mod for the older SKY HD box to allow output via component
