I normally watch sky+ through my BenQ PB8120 via a scart to component lead, which works fine.
I have ordered a SkyHD box which is arriving soon, and wondered how I can watch SkyHd via my projector. Can you advise what would give me the best picture (if at all) ? Listed the projectors connections below. I have read that the new SkyHD boxes dont have a component connection, so am wondering what my options areCheers
Aspect Ratio4:3 (Native), 5:4, 16:9Brightness (ANSI Lumens)1800 ANSI Lumens (Standard)Contrast Ratio2000:1Display Type0.7" DLPResolution (Native / Max)SVGA (800 x 600)
SXGA (1280 x 1024)Video CompatibilityNTSC / PAL / SECAM / HDTVProjection LensF = 2.6 ~ 3.1Number of Colors16.7 Million ColorsSizeDimensions (WxHxD)12.1in. x 3.7in. x 9.4in.
(30.73cm x 9.4cm x 23.88cm)Weight6.8 lbs. (3.08 kg)ConnectivityInputs1 x VGA input - 15 pin HD D-Sub (HD-15)
1 x composite video input - RCA
1 x component video input - RCA x 3
1 x S-video input - 4 pin mini-DIN
1 x audio line-in - RCA x 2
1 x audio line-in - mini-phone stereo 3.5 mmOutputs1 x VGA output - 15 pin HD D-Sub (HD-15)[/B][/B][/B]AudioIntegrated 1 Watt Monaural SpeakerControl1 x serial RS-232
1 x USBOperationPower Supply100 ~ 240 V / 50 ~ 60 HzPower Consumption330WOperating Temperature50°F ~ 104°F (10°C ~ 40°C)Projection LensLamp Type250W UHPLamp Life2000 hrsProjection Distance2.6ft. ~ 32.8ft. (0.79m ~ 10m)Projection Screen Size (Diagonal)20in. ~ 300in. (50.8cm ~ 762cm)Optical Zoom1.2xBrightness Uniformity85%OtherH-Sync Range20 ~ 88 kHzV-Sync Range20 ~ 100 HzMenu LanguagesChinese (traditional), Chinese (simplified), English, German, French, Italian, Spanish, Korean
