sky hd via ext 6 on pd6600
M
markcambs
hi there , new to the forum
just had sky hd installed and use a hitachi 42pd6600 ( which i have to report is problem free) . the sky engineer set it up via the hdmi socket - ext 6. each time i put the tv into standby mode and then turn it back on i have to flick through to ext 6 - a pain . is there any way of avoiding this
thanks
R
roger7248
Only got my HD today. Installer put it in with exactly same cable set up as I had for Sky+, so I am currently experimenting quite a bit with all my various boxes and leads. At the moment lost sound on SD through amp / Dolby box. HD is OK, so using TV sound for that. Will sort it sometime, I hope!
However mine does come on, and in the TV's Feature menu (the middle one of 5 that looks like an antenna), I have Ext2 - out set to EXT 6. Not absolutely sure if that is what is actually making it come on, but worth a try.
S
sws
Im having the same issue, sorry I posted this somewhere else too.
the EXT2 out is for the sound output for using an AMP etc.
Whatever happened to auto-detecting an input with a valid signal ?
Theres no way to store a EXT as say channel 1 from what I can see?
Any help
:lease:
WSH
How about a learning remote that switches on your TV from standby, Sky box on and TV to Ext 6 with one press?
blicky_1
thanks
No, as the previous poster said the only way around this is to use a programable remote, or do what I did and take the TV back in exchange for a 7200 which comes back to the same channel you left it on!
Similar threads
