SKY HD verses DVDO HD +
Discussion in 'Sky Digital TV Forum' started by paul1967, Mar 24, 2006.
  1. paul1967
    paul1967
    Dec 26, 2005
    1,258
    48
    +65
    As it shows in the title i have a DVDO HD + is it worth subsribing to Sky HD. I also have a Z4 projecting on to wall giving a screen size of 96" and sitting about 10 ft away
  2. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    When you say Z4, if you mean a Sanyo PLV-Z4 ... it is HD Ready and can accept 720p and 1080i at 50Hz.
    Your DVDO iScan HD+ will upscale all the regular SD content (most of stuff available) to HD resolutions, you should select 720p to match your projector's native resolution of 1280x720 pixel, and will "pass through" HD content for your projector to process.
    iScan HD+ should do a much better job of upscaling SD to 720p than either the projector itself or the Sky HD stb will do, so it's worth keeping.
    Sky HD should look good with this setup. Is it worth price? That's for you to decide.
    StooMonster
  3. stricko
    stricko
    Jan 20, 2004
    293
    Lambourn
    +6
    Am I right in assuming that you are talking about connecting the Sky HD (Mark 1) to the HD+ via component leads. I thought the HD+ was not HDCP compliant, or does it pass through to the Z4.
    I've got a similar set-up, but most of the time I drive a Pioneer 433MXE from the HD+. Ideally I'd like to have both the plasma and the Z4 connected to the Sky HD
  4. binbag
    binbag
    Jun 16, 2004
    1,717
    North Kent Coast, SE UK
    +81
    HD passes through, HD+ scales (if required).
  5. Welwynnick
    Welwynnick
    Mar 16, 2005
    7,274
    Welwyn, Herts
    +942
    The HD is not HDCP compliant and just passes through.
    The HD+ is HDCP compliant, and processes everything over DVI.
    http://www.dvdo.com/pro/pro_cf.php
    BR, Nick
  6. mediamogul
    mediamogul
    Jan 25, 2002
    500
    Chatham,Kent
    +20
    My HD+ is doing a fantastic job processing Telewest HD,i'm sure it will be the same for sky HD.
    Stuart.
  7. paul1967
    paul1967
    Dec 26, 2005
    1,258
    48
    +65
    how much diff do you see between telewest sd scaled and telewest hd scaled
  8. mediamogul
    mediamogul
    Jan 25, 2002
    500
    Chatham,Kent
    +20
    Quite a big difference HD being jaw dropping and the sd being pretty good,but once you have Hd sd is is the poor relation.I was getting slight flicker on 1080i so use 720p
  9. binbag
    binbag
    Jun 16, 2004
    1,717
    +81
    For me the biggest issue with SkyHD won't be the HD channels but how the SD looks. I watch most of the channels (except shopping) and went back to using RGBs from SDI as the digital stream was too darn honest for the lesser channels against the marginal gain on the better channels that SDI provides.
    Will this be the case over its HDMI output (unscaled or otherwise)? A few more weeks and we'll know. It's a moot point for me as I'm not planning to buy in early anyway.
