Sky HD Signal 'Page'
Discussion in 'Sky Digital TV Forum' started by champagne, Nov 27, 2010.
  1. champagne
    champagne
    Nov 27, 2010
    Hi all
    I've moved from Sky + to sky HD... I seem to be getting no satellite signal at the mo.
    On my sky+ box, I could go into services, 4, 6 to see signal strength and adjust the dish accordingly, but the menus are different on the HD box.
    Can anyone tell me how to view the signal strength page?
    Many thanks.
    Jo
  2. paulr2006
    paulr2006
    Jun 30, 2007
    9,528
    Nottinghamshire
    +2,506
    From Memory (I'm at work) Go into services then settings tab in the menu (Spanner) move down & select signal, use the page - button to page down to get the second input quality :)
    Guessing you have snow on your dish blocking the signal, if you can reach it brush it off with a soft brush.
  3. KeithC
    KeithC
    Dec 19, 2005
    9
    Hello,
    Go to top menu on tvguide and select settings. It is on that page.
    Keith
  4. messenger
    messenger
    Mar 28, 2006
    1,254
    Southend-on-Sea
    +204
    As above will get you there, although adjusting your dish via the signal strength bar is very risky & very hit & miss. Remember to point towards SSE but you would be far better off using a signal strength meter if you can get your hands on one?
