sky hd problems
Discussion in 'Sky Digital TV Forum' started by alboy123, Jan 20, 2008.
  1. alboy123
    alboy123
    Hi, i have just set up my new tosh 37z3030db, no problems there but i have sky hd, I have had a shift around and cut the satellite cables to make them shorter and put new ends on them but now i can't recieve a satelite signal. As far as can see there are not any problems with the cables.
    Would i have damaged the skyhd box or maybe the lnb on the dish has any body got any ideas.
  2. JayCee
    JayCee
    Jan 20, 2004
    23,615
    Lanarkshire
    +2,547
    You will have...if you didn't unplug the Sky box first before cutting?
    If you did unplug it first you've probably just incorrectly fitted the cable ends in the F-Plug, make sure there are no whiskers of the outer braid touching the centre core of the cable.
  3. Grumpyduck
    Grumpyduck
    Jul 15, 2000
    117
    worthing uk
    +14
    See my reply in your other thread.
  4. alboy123
    alboy123
    Thanks fella's, i have checked wiring freys are not touching the centre core, re-booted every time i have checked something the blue screen says NO SATELITE SIGNAL IS BEING RECIEVED.
    Stupid question though does the phone line have to be plugged in, would this make a difference.
  5. JayCee
    JayCee
    Jan 20, 2004
    23,615
    Lanarkshire
    +2,547
    No, it doesn't and it wouldn't.
    You didn't answer my question :lesson: ...did you unplug the box before cutting the cables?
    Be truthful.
  6. alboy123
    alboy123
    Yes i completely stripped my old tv and skyhd box unplugged it all so i could startfrom scratch.
