Sky HD plasma connectivity
Discussion in 'Sky Digital TV Forum' started by paul-saab, Feb 3, 2009.
  1. paul-saab
    paul-saab
    May 13, 2006
    4
    Hi all.
    As a new customer I've decided to go for Sky's recent £49 etc HD deal.
    Problem is, my current plasma (being an old one) has no HDMI connection like the Sky box does. This plasma will be upgraded in the near future but at the moment I would like to get the best out of it as while it still works the missus is putting a block on an upgrade!
    Its an LG MZ42PZ44 with a resolution of only 852x480. It has DVI-D, component video, s-video, VGA and composite input connections. Currently I have a Netgem freeview box connected via component outputs to the plasma (through av amp) and to be honest the picture is pretty good. DVD player is connected by component also and it displays a cracking picture for an old plasma.
    My questions are: Will I be able to use an HDMI to DVI converter plug to connect the Sky HD to the TV? Will the output resolution (480p, 720p or whatever the sky box sends out) work with the DVI-D input on the TV? Will I run into any issues regarding HDCP (plasma non HDCP compliant)? And do the new Sky HD boxes have S-Video outputs?
    Thanks in advance, :thumbsup:
    Paul
  2. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,156
    Poole
    +10,983
    Does the DVI-D have HDCP?
    If you you'll need a Sky HD box with component out, ask Sky.
  3. GasDad
    GasDad
    Remembered (1964-2012)
    Mar 28, 2006
    5,407
    Bristol
    +758
    I don't think this is going to work very well. :(
    Your panel isn't HD ready at least according to the specs on Amazon, and can't as a result handle what the sky HD Box outputs through HDMI / DVI.
    Can I suggest a bunch of flowers as the start of the negotiation process.
  4. alffjeld
    alffjeld
    Jan 7, 2009
    103
    +10
    dont the skyboxes output 480p via hdmi?
    that is what that tv has as native resolution.
    i would have a look in the menu first.
  5. paul-saab
    paul-saab
    May 13, 2006
    4
    No this plasma is not HD ready so I'll be viewing in SD.
    I've gone for the Sky HD as its on offer and the missus wants to be able to record Eastenders and other such rubbish... and when I renew the TV I want the HD source all ready and set up.
    So if I request a box with component outputs can Sky still source these? Why did they drop the component outputs? Reliability issues maybe?
    Alternatively whats everyones thoughts on going for a Scart RGB to component converter? Are they satisfactory in picture quality for the time being?
    Cheers!
  6. Martin J.
    Martin J.
    Dec 19, 2006
    1,406
    +175
    No, given that 480p isn't a valid resolution for UK broadcasts. 576p is the documented minimum output from the Sky box, unless it does something really weird when it encounters a lower EDID. Your display must have HDCP though, or else it won't work full stop, other than via component.
  7. GasDad
    GasDad
    Mar 28, 2006
    5,407
    Bristol
    +758
    That should work - and it will be a good picture (well a good SD picture)
  8. SkyVanMan
    SkyVanMan
    Oct 13, 2008
    160
    +19
    I wouldent request a box with component out to be honest, as you'll get a refurb, no new boxes come with component now unforunatly. To do with copyright issues.
  9. paul-saab
    paul-saab
    May 13, 2006
    4
    Thanks everyone. RGB to component converter it is then. My current freeview box is an old Netgem iplayer with component out and it looks good. Hopefully the RGB/component converter and sky hd box will look as good if not better.
