Sky HD planner filling up with random recordings
Discussion in 'Sky Digital TV Forum' started by Sparkmeister, Jan 8, 2012.
  1. Sparkmeister
    Sparkmeister
    Jul 16, 2004
    121
    Y Fenni
    I have an Amstrad DRX890 Sky HD box. It's been working fine since last April but today I noticed the planner fill up with about 50+ random entries for either planned recordings or recordings that have been attempted and failed, none of which I asked for. The planner also had a few entries called 'Searching', which if you select them, it takes you back to the top of the planner.
    The only change I've made recently was unplugging the telephone connection. I've searched the Internet it seems other people have experienced the same problem (mainly on older Sky+ boxes) but none of the threads I read offered a sensible solution.
    Any ideas?
  2. holiday
    holiday
    Nov 9, 2011
    121
    Leicester
    +4
    You can try to do a rebuild of your sky plus planner go on services,on the remote go down then press 0 0 1 then sky + Rebuild and try that. If I were you try to add the telephone cable in to see if it is that which is causing the issue as well.
  3. Sparkmeister
    Sparkmeister
    Jul 16, 2004
    121
    Y Fenni
    Thanks. Presumably, that won't delete the other stuff in my planner that I want to keep? It also occurred to me that the recordings that I didn't ask for might be the result of Sky Anytime going wrong - something I never use anyway. Any merit in that theory?
  4. holiday
    holiday
    Nov 9, 2011
    121
    Leicester
    +4
    your recordings will still be kept i do not know the asnswer for the second question sorry
  5. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    It's the first time we've had anything like this, or anything at all about the 890, so I don't have a solution other than the rebuild, but I do suggest that you turn off Anytime anyway.
  6. DJMS
    DJMS
    Jun 6, 2007
    794
    28
    Kent
    +72
    I have has smething similar where it says "searching" in place of my recordings. Are you sure these entries are in addition to your recordings and not in place of?
    A full power down always did the trick for me. Havent had the problem for at least 6 months though
  7. Sparkmeister
    Sparkmeister
    Jul 16, 2004
    121
    Y Fenni
    They are in addition to my recordings.
    I did a full power down and the unwanted recordings have stopped for now. I still have "Searching" in my planner, which I guess a rebuild will take care of.
    Thanks.
  8. oosyadaddy
    oosyadaddy
    Apr 30, 2007
    168
    +11
    What make of TV do you have, anything unusual like Baird etc ??
  9. Sparkmeister
    Sparkmeister
    Jul 16, 2004
    121
    Y Fenni
    It's a Panasonic, with an AVR600 receiver inbetween the two.
  10. Miss Chief
    Miss Chief
    Jun 12, 2007
    7,823
    +1,187
    Check your signal, (services, 0, 4) and check you have a signal on input 2.
  11. Sparkmeister
    Sparkmeister
    Jul 16, 2004
    121
    Y Fenni
    The signal strength for inputs 1 & 2 are about 75% and 50% respectively, and showing a signal quality of about 90% and 40% respectively.
    Is that normal / acceptable?
  12. Sparkmeister
    Sparkmeister
    Jul 16, 2004
    121
    Y Fenni
    A rebuild hasn't got rid of the Searching entry in the planner.
  13. simon194
    simon194
    Nov 29, 2006
    1,758
    63
    +209
    The Searching... entries are ones looking for the next episode in a series link. It happens if the next episode is more than 7 days ahead or the broadcaster hasn't flagged the last episode of a series correctly. They usually disappear after 2 or 3 days if they don't link.
  14. ahayes
    ahayes
    Dec 11, 2010
    16
    3
    I have exactly the same problem. My box has set up recording on channels that I don't subscribe to and BBC1 West Mids/East Mids! I have done a planner rebuild but I still keep getting these random recordings.
  15. Sparkmeister
    Sparkmeister
    Jul 16, 2004
    121
    Y Fenni
    Mine started soon after I unplugged the telephone connection. How about you?
    Also, the reandom recording stopped after a power cycle - I just can't get rid of the 'Searching' entry in my planner despite a rebuild.
