Sky HD, Panasonic HDAVI incompatibility
Discussion in 'Sky Digital TV Forum' started by loz, Apr 22, 2007.
  1. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    as discussed in this thread, it seems Sky HD creates problems for users of Panasonic equipment using HDAVI.
    I recently bought a Panasonic DVD recorder. When connected to my Panasonic display using HDMI, then the HDAVI controls work perfectly - switching the display to the right channels, putting the DVD in standby when you switch off the TV, etc. :smashin:
    However, if you then connect SkyHD to the other HDMI port, then even in standby it seems to make the HDAVI control signals go haywire and switching become non-functional or erratic. :mad:
  2. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
    just to clarify. Plugging another HDMI device into the other port doesn't seem to affect the HDAVI signals. It is just Sky HD... :(
