Sky HD on Themescene H30 projector
Discussion in 'Sky Digital TV Forum' started by trainspotter, Mar 28, 2006.
  1. trainspotter
    trainspotter
    Dec 14, 2003
    148
    I currently have Sky+ connected up to my Optoma Themescene H30 projector, The H30 is not listed as "HD Ready".
    So, as I aim to upgrade fully to HD over the next couple of years, will I notice any improvement by replacing my Sky+ for Sky HD without replacing my projector?
    thanks for any advice
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,525
    Kent
    +830
    Yes you will see improvement as the material carries a higher bitrate and a higher resolution. However a HD Ready projector would display it as a sharper image. If you have the H30a (Advanced) then you will be able to use a HDMI connection from a HD source. If you have regualr H30 you will only be able to use component.
